The project is simple... but made to grow!
Revision Log:
2023/08/15 - V0.1 - Original release, Functioned well but burned through batteries
2024/08/18 - V0.2 - Added power save functionality (messy but works)
Overview
There are two main parts to this project: The lid is a simple media player "up-cycled" to be a foux-display for the "cyberdeck". The base is the real interactive portion, with switches, knobs, buttons and LEDs.
The Lid:
The lid contains the up-cycled guts of a video promotional card that I got in the mail. It's a V100-based SBC with 128M flash, low-res LCD, attached LIPO cell, and 3 buttons for play, next, and previous, as well as a magnetic sensor to turn it on when the lid is open and off when shut. The usb port is hot-glued next to the magnetic sensor at the bottom left in order to charge it and load different videos if I want. For now, the buttons are just hot-glued on the back and inaccessible.
The Base:
The main interactive portion is all contained in the base. It houses an Arduino Mega 2560, as well as a power supply that holds 2x 18650 cells in parallel, with built in charge circuit, and 3.3v and 5v boost regulated outputs. I am only using the 5v output. The power supply has a low current sleep-mode that is currently not being utilized, but even if this thing stays on, those cells will take a long time to discharge.
Interactive and Upgradeable
Hardware Design Basics
I designed the base portion to be highly flexible. Each switch has a dedicated input on the Mega, and I grouped the LEDs by switch. For the LEDs next to the switches, the Anodes are powered by an analog output for PWM control of the group, and the cathodes terminate to a Digital output through a current-limit resistor. This allows me to control dimming for each group of LEDs next to a switch as well as which LED is on, and I can turn on all or none. For the LEDs that are by themselves, they each use their own analog output (because I had plenty with the MEGA!) so I can dim them.
Programming Basics
For the moment, Each LED simply displays the status of the switch next to it. This is to start by teaching simple cause-effect behavior. The "simon-says" buttons and LEDs simply light up for 1 second when the associated button is pressed. The potentiometers dim arbitrary sections of LEDs, and I have a floor at 10% so they don't turn off with the pots. Despite my desire to add more features, I made sure it just worked with the basic program.
I utilized ChatGPT to write the majority of the code, as well as help troubleshoot when I had issues. You can find my conversation with ChatGPT HERE.
I created the schematic and simulated the code on wokwi.com prior to loading it on the arduino in the real world. You can access the simulation HERE. You can also copy it and modify it for your specific needs and switch configurations. I think this is much more useful than me posting my final code, as I have several pin assignment changes due to accidental wiring issues (fix it in software they say...).
Future Upgrades
When I designed the switch layout, I had it in mind to create some simple logic puzzles for the next version. Here are my list of updates for V2 of the software, when I make it:
- White toggle switches will activate different modes. Top right will activate puzzle mode (up) or blinky mode (down) on the switches; top left will activate the simon-says game.
- Switch puzzle game: The LEDs by the switches will all turn off except for the top left switch. An LED next to that switch will flash until the switch is set to match. Each time a switch is set to the same position as the flashing LED, the next switch will activate, leading through all 6 switches.
- Blinky mode: Instead of the POTs controlling random dimming, I'm going to change the LEDs to blink/pulse. The middle pot will control the direction (pulse left to right or right to left, with center all at the same time), the left pot will control the frequency of the on/off cycle, and the right pot will control how bright they get.
- Simon Says: This should be self explanatory, but I'll program a short game of simon says, with the lights flashing in a set order that he can learn. Random orders sometime later.
Far-Future upgrades
I have several .96" OLED displays and I left a little bit of space just above the large dial, or I could replace the simon-says LEDs with one. These will enable mini-games to be added, or a user interface. I think I could drive several of these with the Mega.
Another ideal upgrade is to hack the V100 media player, and access it via serial. I can also do some more rudimentary control by just using the outputs of the arduino to control the play/pause, next, previous buttons manually to trigger different videos in a particular sequence. This would not require any major hacking, just clever selection of videos and timing of the arduino control.
Do you want to make one?
This project was highly influenced by just what I had laying around. The big enabler here was actually chat-GPT + wokwi.com for writing the code. I don't have time to write code, and I didn't have hardware until the eleventh hour. I was able to code 99% of this project by telling ChatGPT what I wanted to do and then just iterating within the conversation. Some of the code was written while on my mobile phone in the conversation, just continuing to iterate through various aspects of the programing while I was waiting in a car line, sitting at lunch, or at other times when my laptop was out of reach.
I have 4 kids, and without this help I would never have finished, or even come close. This is the first project I have been able to work on in a long time and I owe it to OpenAI and their amazing work on LLMs producing GPT4. If you're not utilizing this tool, you need to get on board NOW.
If you have kids and find projects difficult, use this one as a framework for what you can do in a short period of time by leaning on ChatGPT to take a ton of the work and do it for you.
Just Ask.
If you want some help making something for your kid, just drop me a line! I will gladly point you in the right direction and help you on your own journey.
