Firmware V0.1 Complete
A project log for Toddler's Cyberdeck
I'm built a cyberdeck for my son. He was 2 when I built it. He's still using it today.
joshJosh • 07/18/2023 at 22:12•0 Comments
Just over a week of chatting with ChatGPT-4 and I have working code! At least it works on wokwi.com... I still need to load it to the real hardware.
It works, but there are a few things I don't like:
  1. The array of "all leds" doesn't include the simon says leds.
  2. The dimming is a little funny because I wanted the pots to do something but I'm leaving the addition of .96" OLED screens for a later upgrade.
  3. It doesn't have any "cool" things like patterns or dimming when it is turned on.
  4. It was written by a LLM and I have not tried any optimization at all.
But since it works, I need to STOP coding and work on other stuff... like building the physical hardware. I have 4 days left.
Here it is in all its glory, or shame...
// -----------------------------Include libraries -------------------
#include <Arduino.h>
// -----------------------------Define variables----------------------
int debounceDelay = 50;
int minLEDdim = 10; // minimum LED dim level (never let the pots turn the LEDs off completely)
// -----------------------------Define structures---------------------
struct Switch {
  String name;
  int pin1;
  //  int pin2;  // for SP3T, 0 for SPST (pin 2 is always gnd - no definition req'd)
  int pin3;  // for SP3T, 0 for SPST
  int state1; // the states match the LED structure for easy matching
  int state2; // this will be set to high if state 1 and 3 are low
  int state3; // this should initialize at low and stay low for SPST switches (which don't have a third state)
struct LEDSet {
  String name;
  int dimPin; // for sets of leds that only have one, only the dim pin and dim level is used
  int pin1; // Used for 2 or 3 LEDs, 0 if 1 LED
  int pin2; // Used for 2 or 3 LEDs, 0 if 1 LED
  int pin3;  // Used for 3 LEDs, 0 otherwise
  int state1;
  int state2;
  int state3;
  int dimLevel;
struct Button {
  String name;
  int pin;
  int state;
  int lastState;
  unsigned long lastDebounceTime;  // add debounce time
  //int debounceDelay;  // the debounce time; increase if the output flickers
struct Potentiometer {
  String name;
  int pin;
  int state; //this will utilize the analog in values from 0-1024
struct SimonLED {
  String name;
  int dimPin;
  int dimLevel;
  unsigned long turnOffTime;
// ----------------------instances of structures----------------------------
// Switch instances (set here is teh set of data for one switch)
// struct: name, pin 1, pin 3, State 1, State 2, State 3)
Switch SWset1 = {"PowerSwitch1", A13, 0, LOW, LOW, LOW};
Switch SWset2 = {"PowerSwitch2", A14, 0, LOW, LOW, LOW};
Switch SWset3 = {"SelectionSwitch1", A12, 0, LOW, LOW, LOW};
Switch SWset4 = {"SelectionSwitch2", A15, 0, LOW, LOW, LOW};
Switch SWset5 = {"SP3T1", 22, 23, LOW, LOW, LOW};
Switch SWset6 = {"SP3T2", 24, 25, LOW, LOW, LOW};
Switch SWset7 = {"SP3T3", 26, 27, LOW, LOW, LOW};
Switch SWset8 = {"SP3T4", 28, 29, LOW, LOW, LOW};
Switch SWset9 = {"SPST1", A10, 0, LOW, LOW, LOW};
Switch SWset10 = {"SPST2", A11, 0, LOW, LOW, LOW};
// LED instances (set here is up to 3 LEDs and associated with the same switch number)
// struct: name, dim pin, pin 1, pin 2, pin 3, State 1, State 2, State 3, dimlevel)
LEDSet LEDset1 = {"PowerLED1", 6, 0, 0, 0, HIGH, HIGH, HIGH, 128};
LEDSet LEDset2 = {"PowerLED2", 7, 0, 0, 0, HIGH, HIGH, HIGH, 128};
LEDSet LEDset3 = {"null", 0, 0, 0, 0, HIGH, HIGH, HIGH, 0};
LEDSet LEDset4 = {"null", 0, 0, 0, 0, HIGH, HIGH, HIGH, 0};
LEDSet LEDset5 = {"SP3TSetLED1", 2, 30, 31, 32, HIGH, HIGH, HIGH, 128};
LEDSet LEDset6 = {"SP3TSetLED2", 3, 33, 34, 35, HIGH, HIGH, HIGH, 128};
LEDSet LEDset7 = {"SP3TSetLED3", 4, 36, 37, 38, HIGH, HIGH, HIGH, 128};
LEDSet LEDset8 = {"SP3TSetLED4", 5, 39, 40, 41, HIGH, HIGH, HIGH, 128};
LEDSet LEDset9 = {"SPSTSetLED1", 44, 43, 42, 0, HIGH, HIGH, HIGH, 128};
LEDSet LEDset10 = {"SPSTSetLED2", 45, 49, 48, 0, HIGH, HIGH, HIGH, 128};
// Potentiometer instances
Potentiometer Pot1 = {"Potentiometer1", A0, 0};
Potentiometer Pot2 = {"Potentiometer2", A1, 0};
Potentiometer Pot3 = {"Potentiometer3", A2, 0};
// Create instances of the Buttons
Button ButtonDown = {"Down", 50, HIGH, HIGH, 0};
Button ButtonUp = {"Up", 51, HIGH, HIGH, 0};
Button ButtonLeft = {"Left", 52, HIGH, HIGH, 0};
Button ButtonRight = {"Right", 53, HIGH, HIGH, 0};
// Create instances of the simon says LEDs
SimonLED SimonLEDLeft = {"Left", 8, 0, 0};
SimonLED SimonLEDRight = {"Right", 9, 0, 0};
SimonLED SimonLEDUp = {"Up", 10, 0, 0};
SimonLED SimonLEDDown = {"Down", 11, 0, 0};
//------------------------------Arrays of Structures-----------------------
//This could be combined with the above, if the code doesn't need to individually
//call the above structure instances, but I'm keeping them separate for the moment.
// Array of all potentiometers
Potentiometer allPots[] = {Pot1, Pot2, Pot3};
// Array of all switch sets
Switch allSwitches[] = {SWset1, SWset2, SWset3, SWset4, SWset5, SWset6, SWset7, SWset8, SWset9, SWset10};
// Array of all LED sets
LEDSet allLEDs[] = {LEDset1, LEDset2, LEDset3, LEDset4, LEDset5, LEDset6, LEDset7, LEDset8, LEDset9, LEDset10}; // Add LEDset9 and LEDset10
// Array of all buttons
Button allButtons[] = {ButtonDown, ButtonUp, ButtonLeft, ButtonRight};
// Array of simon LEDs
SimonLED simonLEDs[] = {SimonLEDDown, SimonLEDUp, SimonLEDLeft, SimonLEDRight};
//--------------------------------Functions --------------------------------
void checkSwitchStates() {
  for (int i = 0; i < sizeof(allSwitches) / sizeof(Switch); i++) {
    // Check the state of pin 1
    if (digitalRead(allSwitches[i].pin1) == LOW) { //switches are to ground with input pullup. Low means switch is "on" or "up".
      allSwitches[i].state1 = LOW;
    } else {
      allSwitches[i].state1 = HIGH;
    // If pin 3 exists, check its state. This only for SP3T switches.
    if (allSwitches[i].pin3 != 0) {
      if (digitalRead(allSwitches[i].pin3) == LOW) { //Low here means SP3T switch is "Down"
        allSwitches[i].state3 = LOW;
      } else {
        allSwitches[i].state3 = HIGH;
    } else {
      allSwitches[i].state3 = HIGH; //if pin 3 is 0 then it's a SPST switch and we keep state 3 High (off)
    // Set state2 LOW if states 1 and 3 are HIGH (off)
    if (allSwitches[i].state1 == HIGH && allSwitches[i].state3 == HIGH) {
      allSwitches[i].state2 = LOW;
    } else {
      allSwitches[i].state2 = HIGH;
void matchLEDStates() {
  for(int i = 0; i < sizeof(allSwitches) / sizeof(Switch); i++) {
    if (allLEDs[i].name != "null") {
      allLEDs[i].state1 = allSwitches[i].state1;
      allLEDs[i].state2 = allSwitches[i].state2;
      allLEDs[i].state3 = allSwitches[i].state3;
void updateLEDs() {
  for(int i = 0; i < sizeof(allLEDs) / sizeof(LEDSet); i++) {
      // If the LED set only contains one LED and no control pins,
      // turn it off when state1 is HIGH by setting analogWrite to 0.
      if(allLEDs[i].pin1 == 0 && allLEDs[i].pin2 == 0 && allLEDs[i].pin3 == 0 && allLEDs[i].state1 == HIGH) {
        analogWrite(allLEDs[i].dimPin, 0);
      } else {
        // Turn on or off each LED based on its state by matching the switch state (LOW is ON)
        if(allLEDs[i].pin1 != 0) {
          digitalWrite(allLEDs[i].pin1, allLEDs[i].state1);
        if(allLEDs[i].pin2 != 0) {
          digitalWrite(allLEDs[i].pin2, allLEDs[i].state2);
        if(allLEDs[i].pin3 != 0) {
          digitalWrite(allLEDs[i].pin3, allLEDs[i].state3);
        // Update the brightness level
        analogWrite(allLEDs[i].dimPin, allLEDs[i].dimLevel);
void checkPotentiometers() {
  for(int i = 0; i < sizeof(allPots) / sizeof(Potentiometer); i++) {
    // Read the value of the potentiometer (from 0 to 1023)
    allPots[i].state = analogRead(allPots[i].pin);
    // Scale the value down to between 0 and 255
    allPots[i].state = map(allPots[i].state, 0, 1023, 0, 255);
    // Print the potentiometer state to the serial monitor
    //Serial.print(allPots[i].name);
    //Serial.print(": ");
    //Serial.println(allPots[i].state);
void setLEDDimming() {
      // Use the state of the corresponding potentiometer to set the dimming level
      allLEDs[i].dimLevel = max(allPots[i % (sizeof(allPots) / sizeof(Potentiometer))].state, minLEDdim);
    // Print the LED dimLevel to the serial monitor
    //Serial.print(allLEDs[i].name);
    //Serial.println(allLEDs[i].dimLevel);
  //set the dim level for the simon leds, but use the pot on the left
  for (int i = 0; i < sizeof(simonLEDs) / sizeof(SimonLED); i++){
    if (simonLEDs[i].name != "null") {
      simonLEDs[i].dimLevel = max(allPots[0].state, minLEDdim);
void checkButtons() {
  for (int i = 0; i < sizeof(allButtons) / sizeof(Button); i++) {
    int reading = digitalRead(allButtons[i].pin);
    if (reading != allButtons[i].lastState) {
      allButtons[i].lastDebounceTime = millis();
    if ((millis() - allButtons[i].lastDebounceTime) > debounceDelay) {
      if (reading != allButtons[i].state) {
        allButtons[i].state = reading;
        // Print the button state to the serial monitor for debugging
        Serial.print(allButtons[i].name);
        Serial.print(": ");
        Serial.println(allButtons[i].state == HIGH ? "HIGH" : "LOW");
    allButtons[i].lastState = reading;
void controlSimonLEDs() {
  for (int i = 0; i < sizeof(simonLEDs) / sizeof(SimonLED); i++) {
    if (allButtons[i].state == LOW && millis() >= simonLEDs[i].turnOffTime) {
      simonLEDs[i].turnOffTime = millis() + 1000;
      analogWrite(simonLEDs[i].dimPin, simonLEDs[i].dimLevel);
    } else if (millis() >= simonLEDs[i].turnOffTime) {
      analogWrite(simonLEDs[i].dimPin, 0);
//------------------------------End Functions Section-----------------------------
void setup() {
  // Initialize the serial communication at baud rate of 9600
  Serial.begin(9600);
  // Initialize switch pins as inputs with pullup resistors
  for(int i = 0; i < sizeof(allSwitches)/sizeof(Switch); i++) {
    pinMode(allSwitches[i].pin1, INPUT_PULLUP);
      pinMode(allSwitches[i].pin3, INPUT_PULLUP);
  // Initialize LED pins as outputs
  for(int i = 0; i < sizeof(allLEDs)/sizeof(LEDSet); i++) {
    pinMode(allLEDs[i].dimPin, OUTPUT);
    pinMode(allLEDs[i].pin1, OUTPUT);
    if (allLEDs[i].pin2 != 0)
      pinMode(allLEDs[i].pin2, OUTPUT);
    if (allLEDs[i].pin3 != 0)
      pinMode(allLEDs[i].pin3, OUTPUT);
  // Initialize potentiometer pins as inputs
    pinMode(allPots[i].pin, INPUT);
  // Initialize button pins as inputs with pullup resistors
    pinMode(allButtons[i].pin, INPUT_PULLUP);
  // Initialize SimonLED pins as outputs
    pinMode(simonLEDs[i].dimPin, OUTPUT);
void loop() {
  checkSwitchStates();
  matchLEDStates();
  checkPotentiometers();
  setLEDDimming();
  updateLEDs();
  checkButtons();
  controlSimonLEDs();
  //delay(500);
  // Other code...
