This Project is based on IR receiver; IC 555; IC 7474; BC 187.Here we have made use of TSOP 1738, an IR receiver which detects the IR rays
This Project is based on TSOP IR receiver; IC 555; IC 7474; BC 187.Here we have made use of TSOP 1738, an IR receiver which detects the IR rays from the remote. IC NE555 is the next important part which produces a clock pulse for toggling the D flip flop.The relay helps to connect any electrical devices to the circuit and you can control any electrical equipment, like light and fan. You must need regulated power supply of 5 volt to do this circuit because TSOP requires 5v. Its voltage should not exceed 5V
component list
