AArduino ATmega328p extra mini board.
A smallest version of arduino minimal board.
Many other boards are huge.
Here is a very tiny arduino board.
After you'r polished the project enough, time to pack it.
Only 12.5mm X 25.5mm in size!
Can be flashed with arduino bootloader before or after soldering.
All pins are exposed on the back-board.
22 pads plus serial and additional power via 1.27mm pin header.
Version 0.9 is a complete version for now.
Unlit bug being found.
Free for privet use.
aarduino_jlpcb.7z
complete for jlpcb
7-Zip - 14.49 kB - 07/16/2023 at 21:09
Download
aarduino_pcbway.zip
complete for pcbway tested.
x-zip-compressed - 26.86 kB - 07/16/2023 at 21:09
Download
  • 1 × ATmega328p-au, TQFP
  • 1 × 16mHz quartz, 5.0x3.2mm.
  • 1 × Programming pin header, 5 pins, P1.27.
  • 11 × Some Rs, Cs and LEDs, 0805. About 11 PCs. See schematic.
soni wrote 12/13/2024 at 18:30 • point
Arduboy , meybe add power, more key, knob/rotor and solar panel?
Matt wrote 07/17/2023 at 16:16 • point
Looks cool and I can think of a few ways I'd use this. The pin labels on the back or ambiguous though--not obvious which label belongs to which pad.
Sziklai wrote 07/18/2023 at 21:43 • point
Sad to hear and thank you for feedback!!!
Ive added the last photo. Please take a look, that's why labels are looking strange.
When someone solder a pin header he'll see only half of labels.
There is another way to remember:
Clockwise from six while bottom view -> PWR, D2->D13, A0->A7, GND. That's all. Should be quite simple.
(Answer why board is so overloaded with routes and vias. lol that's why).
Thank you.
