Under water microscopy
A project log for Spark erosion: Detailed view, simple machinery
Have a close look at how Electrical Discharge Machining (EDM) works and what can be achieved with a simple setup
norbert-heinzNorbert Heinz 07/25/2023 at 09:240 Comments
I have added a tub, glued from plastic sheets to my EDM machine:
and installed the windshield washer pump from a car to flush the drilling site with water. I got the pump from the scrap dealer around the corner for 5 euros. So that the water doesn't splash too much and the pump doesn't overheat during continuous operation, only 3.3V are applied to the terminals:
To make you see what difference the flushing makes, I had to prepare my microscope for under water operation. A short steel tube with a glass bottom does the job:
With an extension of the tub, I am now prepared to record under water timelapse videos with my microscope:
Rich text editor
