PiZero-ME-MAX
Just a simple PCB that will allow you to mount a Raspberry Pi zero inside of a phoenix contact ME MAX housing
The plan is to create a PCB that will allow you to place a raspberry pi zero in a ME-MAX housing so that it can be mounted on DIN rail as often used in industrial applications.
It will be designed to fit into the housing with 6 4pin conntectors.
It will also include the following circuitry.
- 24Vdc to 9Vdc converter - DC-DC, so that a CAN bus can be established on the backplane
- 9Vdc to 5Vdc converter - probably linear to drive the raspberry pi zero
- CAN transceiver for backplane (model mix)
- RS-485 transceiver for backplane (model mix)
The following external connections will be fixed:
- Serial port accessible from one of the external connectors
- 24VDC from one of the external connectors
- CAN or serial or RS-485 available from the T-BUS
- 24VDC available from the T-BUS
00825556_MSTBO_2.5_4-P-R.pdf
Adobe Portable Document Format - 85.03 kB - 01/02/2017 at 22:39
Preview
00613164_MSTBO_2.5_4-P-L.pdf
Adobe Portable Document Format - 84.85 kB - 01/02/2017 at 22:39
Preview
2200326.pdf
Adobe Portable Document Format - 96.99 kB - 01/02/2017 at 22:33
Preview
2200325.pdf
Adobe Portable Document Format - 96.87 kB - 01/02/2017 at 22:33
Preview
MP1584EN data sheet.pdf
Data sheet for DC-DC converter
Adobe Portable Document Format - 387.24 kB - 12/31/2016 at 14:33
Preview
