Battery is running longer then i really dreamed, easily an hour to one bar. The pi is secured with m2 screws, will secure the rest of the parts with vfb tape. Someday if I decide to reprint the base so I'll modify the design to use more screws but low on plastic and have used enough filament this month.
Matthew H
