AutoDuct Block Diagram
A project log for AutoDuct smart motorized air duct shutter
Smart motorized air duct shutter with wireless connectivity for decentralized ventilation systems
coltfischColtfisch • 09/11/2023 at 19:50•0 Comments
The electronics of the AutoDuct unit is divided into two PCBs: the main control PCB containing the microcontroller, the power supply circuit and the shuttor motor driving circuit is located on the back of the linear actuator assembly. A second PCB is hidden behind the front cover of the unit. It contains the HM-17 BLE communication module, a real-time-clock IC, a configuration EEPROM and a SHT31 temperature/humidity sensor.
The two end stop sensors for the shutter control are placed on a separate PCB and integrated inside of the linear actuator.
