These are my renderings of the original idea I had at university.
The concept depicts a flat and wide copper conductor that transfers the low voltage current from the panels to an inverter on the inner window sill.
In this project I am searching fo a DIY approach to achieve the same result or a similar approach that proves to be safer and cheaper.
