- Please, please, upload gerbers, in a ZIP - don't make others generate gerbers for you. I don't have Eagle installed, for example, and thus can't generate gerbers from Eagle - and gerbers is the universally accepted standard. After generated, ZIP them up, check them here and then upload them to "Project files" section or link them in the project comments, I'll take care of the rest =)
- Having a description would be awesome. "SOIC-8 breakout" is a good description, "Power rail breakout" is not, unless you provide pictures/link to online viewer - and "0.1in header power rail breakout - 3x10, 3 rails" + picture is just great! (sometimes, linking your Hackaday.io project is sufficient if it's about the board in question)
- If possible, and I really hope you do that, please include source files - GitHub link will be great, too.
This is a good example of a board description for a board with active components that actually does something useful.
you could have said something :p
Hey, that's not about you, I was going to go through your boards yourself =) Sorry it looks that way, I just took it as an example because I understood this would be kinda hard to manage.
