Sliding Gate Automation
Ever had an automatic Sliding Gate installed at your house only to open and close it manually. An easy method to get the system running.
In this project I utilize the power of Arduino to create a circuit to power a Sliding Gate. The main aim of this project is to utilize a dead Sliding gate with a functioning single phase AC motor and automate the system using an Arduino, couple of relays, a 433MHz reciever, a 433Mhz transmitter and some crafty electrical skills. The system creates a method of powering the gate's motor when required and to decide whether to open or close the gate.
The Arduino Uno constantly listens to a set response from the transmitter, in this case it is the remote used to open or close the gate. The transmitter operates on two channels, where each channel has its on unique ID. Once this ID is recieved by the 433MHz reciever, it sends a signal to the Uno which controls the Relays to power the motor.
Methodology
Step 1 : Powering the motor
The configuration to power the motor is shown below. In order for the motor to move the gate in the forward(close) direction, the Main winding should be connected to the main’s power.
In order for the motor to move in the opposite(open) direction, the Secondary winding should be connected to the main’s power.
It is necessary to identify which wire corresponds to which winding. Usually the wires are not labelled and this can be identified with trial and error by supplying AC power to the wire.
In my case, I was working with a 220~240VAC motor. I was able to identify the Neutral wire easily as it was blue in color which is a standard color used to indicate the Neutral terminal.
Next, I connected the Live terminal to the red wire, which made the motor turn in the forward direction. This indicated that I supplied power to Main Winding of the Motor.
Note: Make sure that the starter capacitor is connected properly and functioning. This ensures that the motor has adequate starting torque.
Wiring diagram to close the gate (motor moving forward)
Wiring diagram to open the gate (Reversing the motor)
Step 2 : Stopping the motor
The mains power is provided to the motor through a limiter switch. As soon as the gate reaches one end the limiter switch is triggered which opens the circuit and stops the main’s from supplying power to the motor.
Step 3 : Using relays to control the motor
The relay has two contact points; Normally open and Normally closed.
The Normally closed path is used to power the Main winding of the motor. This was chosen to ensure that when the system was reset or if something went wrong in the system, the motor would ensure that the gate was kept closed at all times.
The Normally open path is used to power the Secondary winding of the motor. The normally open path is closed when the coil inside the relay is energized. This can be done by sending a 5V signal from the Arduino as the relays used are operating under 5V.
By using two paths to power the motor ensures that power is not provided simultaneously to the Main and Secondary windings of the motor.
This Relay(R2) is operated through pin 8 of the Arduino.
A second relay(R1) is used to break the circuit in order for the motor to stop if the Arduino receives the command from the receiver while the gate is moving.
The Arduino constantly checks the receiver if it has received any command. Once a command is issued the Arduino reroutes power to the motor in order for it to close or open the gate.
The main purpose of the second relay is to give the system enough time to reroute the system to power the motor without instantly changing the direction at which the motor is turning. Once the rerouting is complete the relay switches off and power is supplied to the motor to turn in the opposite direction.
This Relay is operated through pin 9 of the Arduino.
Purpose of the Second Relay
If the system is halfway through closing the gate and receives the command from the receiver to open the gate, the relay is activated to reroute power to the secondary winding. Since this happens almost instantaneously the relay is under constant pressure from the reverse voltage generated by the motor due to sudden seize of power onto the main winding. Furthermore, damaging the contacts of the relay permanently if continuously stressed.
With the help of an additional relay the power supply is disconnected to the motor and gives the system a time of 10 seconds to reroute power to the necessary windings. This reduces the stress on the contacts of the relay and increasing their lifetime.
Overview of the wiring of the system
Relay protection method:
Suppression Capacitors
When a DC motor is suddenly stopped a negative current loop is created by the coil of the motor, this is due to the inductive properties of a coil. However this can be neutralized by installing a feedback diode to provide a path for the negative current to flow.
When an AC motor is suddenly stopped through a switch it creates... Read more »
View project log
  • 1
    Step 1
    Build Log
View all instructions
Rich text editor
