Glued with Araldite epoxy resin (also fills the gap)
With inner and outer display frameWith keyboard mount (which is also the 2nd part of the bottom cover (white)
Testing my new CAD skills: the bottom cover (white) seems to fit with the inner display frame (black resting on the little white feet of the bottom cover).
