First i got my cheapest scope and found data and clock. Unlike stainless calipers they are separate signals. You will also need to breakout at least on/off or it will shutdown and stop sending signals. It is BCD type caliber (or B type in some webpages).
CLOCK signal:
DATA signal:
Next i will disassemble again, connect ON/OFF switch, connect nano328-ch340g and try to decode the signals.
