The idea is to make a simple kit to convert tractors and other vehicles to remote driving so they can be used in hazardous environments.
Basically install a kit in and hook it up to battery/generator and set waypoints to drive and put the vehicle in drive/1st gear+speed setting. One motor will steer and the other motor will do brake/clutch control.
For example using the kit to make a mine clearing tractor in Ukraine with any normal vehicle.
Corsix
Arturo
Nicholas Stedman
