Development Stage and Future Plans
The entire project is built in Micropython, using several libraries including a Microdot-based webserver, a mDNS library, and numerous custom libraries designed for rapid board bringup and configuration handling.
At present, the project is in the early stages of development and a roadmap is yet to be established. One of the primary next steps will be to devise a concrete plan that details the different stages of development and the features to be incorporated at each stage. The overarching goal is to create a versatile, easy-to-use, and highly customizable LED controller that stands out from the crowd.
If you're interested in LED lighting and looking for a DIY project with a good balance of hardware and software aspects, then stay tuned for more updates on this exciting project!
