![](https://cdn.hackaday.io/images/6353811693577402535.jpg)
Panels were added to hide wiring and clean things up a bit in the back. The panel which housed eth0/audio/extra USB and charging port was modified and now only houses the audio and charging port. The extra USB port is now going to connect to a 1tb SSD which will be housed under the keyboard panel. The eth0 port will also be mounted in the keyboard panel. I am now on to reworking the keyboard panel which will be comprised of multiple smaller panels with some storage for some tools and antennas. I am also going to add a emblem to the outside of the case, but that's last on the list.
