The project consists of 2 main parts:
Hardware:
Minitel ESP32 board by iodeo
https://hackaday.io/project/180473-minitel-esp32
https://www.tindie.com/products/iodeo/minitel-esp32-dev-board/?utm_source=hackadayio&utm_medium=link&utm_campaign=project_buynow
Good ressources are available on :
Software:
Minitel library by eserandour
Huge thank you!
github: https://github.com/eserandour/Minitel1B_Hard
Universal-Arduino-Telegram-Bot by Brian Lough
Huge thank you!
github: https://github.com/witnessmenow/Universal-Arduino-Telegram-Bot
YouTube: https://www.youtube.com/brianlough
Tindie: https://www.tindie.com/stores/brianlough/
Twitter: https://twitter.com/witnessmenow
My code is pretty dirty, but it kind of works.
You need to create a bot in Telegram (Brian explains how very clearly in his videos)
Then, get the token from Botfather
The code could be improved, but my version of Minitel is not really responsive to some "advanced" functions used in the library. Formating is kind of limited if you see what I mean...
NEW: Code is now available on github.
https://github.com/goguelnikov/TelegramMinitelChat
Do not hesitate to propose modifications and improvements!
