some very late updates/additional information
A project log for project Acidfish
beautiful watertight watch with always on bubble display, LoRaWAN and USB made to last a lifetime
erisEris 08/16/2024 at 01:471 Comment
-still havn't worked on the firmware any more but wearing the watch anyways and it works! it just still displays winter time since i still have to reflash the watch to set the time and i havn't done that. in practice the battery lasts about 2.5 days, which i'm pretty happy with, though further improvements could certainly be made.
-at some point made a really nice dev board with 2 usb c ports, one for the watch and one for the compter, it has an intigrated 2 port usb 2.0 hub so i can connect the watch usb and the built in rp2040 serving as an swd debugger simultaneously with only one usb cable. the usb ports are kinda finicky bc my soldering sucked but it's still a pretty nice experience.(obviously also has usb boot and reset buttons for both watch and debug rp2040)
-i never mentioned it has an ambient light sensor. it does that! and that's even actually implemented in firmware. the display doesn't get bright enough for direct sunlight(and an overflow(i think in the ALS itself) means the display shuts off when there's too much light but given it's not readable anyways that's basically a feature) since i'm nocturnal it still shows me the time a lot clearer than a non LED watch probably would most of the time and i'm pretty happy with it, though i might be able to increase the display regulator voltage a bit and squeeze a bit more light out of them to cover a slightly broader range of lighting conditions. i also think if i ever make a v2 it should probably have red acrylic over the display to minimize reflections and make the display even more readable.
-RP2040 power management sucks ass. for my typical (mostly low light) operating conditions it tends to draw more current than the display(i think around 5mA but it's been a while so don't 100% on that).
i even fully re wrote the pio display program and interface driver to not use DMA(just stores display values in it's registers) and while i'm proud of the PIO code and had a lot of fun writing it(was quite close to hitting the limit of what i could do with PIO alone, was syncing 7SMs over the two blocks, very enjoyable puzzle) it didn't decrease power consumption one bit.
it could probably be significantly improved by supplying core voltage with an external switching regulator and potentially switching to a specialty low power oscillator instead of the built in one with external crystal. but it's still very frustrating to see how i can't just turn off everything except the PIO and wake on pin change interrupt.
the clean and most efficient way to solve this would obviously be to move to an FPGA or something like that for the display driver and maybe even just also stick a risc v core on there and abandon RP2040. however learning that stuff seams scary and the above mentioned incremental improvements might be enough to not make me quite so upset with the amount of power that's just being wasted.
alternatively i could switch to something with a more conventional low power co processor like an esp32(with free wifi and BT, though i don't know what i'd need that for(maybe alarms over bluetooth speaker)) IF that has competent power management, but i really like the PIOs, they're so fun and never halt, so the GPIO state never gets stuck and the display is pretty much safe from burning out due to a segment being on for too long(did i even mention this? u can run these displays at up to 100mA peak but if it takes more than 1ms to switch to the next segment or average is over like 5mA it might die or at least come closer to death). I'm assuming i could protect the leds in a similar way if i was using an FPGA.
yes RP2350 has an integrated switching regulator for core voltage but i don't think it's very efficient. ur not even supposed to use it for output current under 1mA bc LDO is more efficient then, that doesn't inspire confidence. would still wanna get a good external one) and the power management improvements besides that look like a token effort at best(power domains, but the cores and all they're periphery are one domain so what the fuck is that supposed to be for turning off some ram isn't gonna save my battery life.
-the way i made the seal is crap, one of the buttons fell out, currently covered with tape, need to do the o ring thing
Eris wrote 08/16/2024 at 02:02 point
oh yeah, and it keeps remembering the time since i programmed it when it wasn't daylight savings time because there's a circuit shutting off everything but the RTC when the battery voltage is below like 3.4V or something so even when it can't display the time anymore it should be able to remember it for months.
