BackSpace [8] & Ctrl-C [3] now works from Serial term
NEW [v] stll bugged (don't give hand back)
TONE [v] play a tone on speaker
NOTONE [v] mute speaker
PLAYT5K [v] PLAYS a T5K tune
PLAYT53 [v] PLAYS a T53 tune
LED [v] LED 1,1 turn on 1st led
RSEED [v] does nothing ...
DELAY [v] wait for x milliseconds
PRINT / ? [v] still have to distinguish ',' & ';'
OUT [v] print a char of ascii code <x>, can be redirected to FILEIODesc
CLS [v] clear current screen (LCD_BUILTIN, later : VGA ....)
REM [v] make a line comment
FILES [v] list storage content
CAT [v] read a specific file (w/o interpret it)
DELETE [v] erase a file from storage
DUMPSTS [v] dump serial to SD file
WRITE [ ]
WRITETEXT [ ]
LIST [v] List content of PRGM memory [ need checkbreack() ]
RUN [v] Run content of PRGM memory [ need checkbreack() ]
LOAD [v] (does it starts by a 'NEW' statement ? // I think not // so lines could be merged)
SAVE [v] Save content of PRGM memory
FOR [ ] FOR / TO / [STEP] / NEXT
IF [v] IF <bool expr> THEN ...
GOTO [v] Jump directly to a line
GOSUB [v] Jump to line after saving current position
RETURN [v] return to current position after GOSUB
END / STOP[v] STOPS execution of current program
RND(x) [v] return int between 0 & x
CHR$(x) [v] return ASCII char from x
STR$(x) [v] return string representing number x
FREE() [v] return ammount of free RAM in bytes (beware it's an int not a short)
