ADDED support for STRING & INT arrays ADDED support for Bitmap files BackSpace [8] & Ctrl-C [3] now works from Serial term NEW [v] reset PRGM & VARS BEEP [v] duration * 50ms / 1..48 octave #2 to #5 / else frequency (49..4096) TONE [v] play a tone on speaker NOTONE [v] mute speaker PLAYT5K [v] PLAYS a T5K tune PLAYT53 [v] PLAYS a T53 tune LED [v] LED 1,1 turn on 1st led // LED 3,0 turn off 3rd RSEED [v] does nothing ... DELAY [v] wait for x milliseconds PRINT / ? [v] still have to distinguish ',' & ';' OUT [v] print a char of ascii code , can be redirected to FILEIODesc CLS [v] clear current screen (LCD_BUILTIN, later : VGA ....) LOCATE [v] Set text cursor position (x,y) PSET [v] set a pixel (since git:6266540) PRESET [v] clear a pixel (since git:6266540) LINE [v] draws a line (since git:6266540) CIRCLE [v] draws a circle (since git:6266540) DRAWBMP [v] draw a bitmap from storage INPUT [v] INPUT content into a variable (NUM or STR) -> can use FILEIODesc to select stream INPUTSTR [v] INPUT content into a variable (STR) -> can use FILEIODesc to select stream REM / ' [v] make a line comment FILES [v] list storage content CAT [v] read a specific file (w/o interpret it) DELETE [v] erase a file from storage DUMPSTS [v] dump serial to SD file // DUMPSTS "" -> read until timeout WRITE [ ] WRITETEXT [ ] LIST [v] List content of PRGM memory [ need checkbreack() ] RUN [v] Run content of PRGM memory [ need checkbreack() ] LOAD [v] (does it starts by a 'NEW' statement ? // I think not // so lines could be merged) SAVE [v] Save content of PRGM memory // slow impl. .... // auto-adds '.BAS' if needed CHAIN [v] => NEW / LOAD / RUN a program FOR [ ] FOR / TO / [STEP] / NEXT IF [v] IF THEN ... GOTO [v] Jump directly to a line GOSUB [v] Jump to line after saving current position RETURN [v] return to current position after GOSUB END / STOP[v] STOPS execution of current program -------------------------- RND(x) [v] return int between 0 & x CHR$(x) [v] return ASCII char from x STR$(x) [v] return string representing number x ASC(x) [v] return ASCII code of 1st char of 'x' string STRLEN() [v] length of a String value LEN() [v] length of a String value LEFT$() [v] return left chars of a string RIGHT$() [v] return right chars of a string MID$() [v] return substring of a string INSTR() [v] return first occurence of a substring in a string FREE() [v] return ammount of free RAM in bytes (beware it's an int not a short) MEM() [v] return ammount of free RAM in kilobytes (cause it's a short @this time) BTN() [v] returns 0,1,2,4 => Cf pressed user btn(s) INP() [v] wait for a char from input // can use FILEIO-Desc SNS() [v] read for a char from input (0 if none) // can use FILEIO-Desc SECS() [v] seconds since MCU booted
