The enclosure was not very pretty to look at. I used some mild abrasive to clean it up.
![](https://cdn.hackaday.io/images/4704481691336474369.jpg)
And the side:
![](https://cdn.hackaday.io/images/2760191691336589575.jpg)
It came out like this:
![](https://cdn.hackaday.io/images/5388391691336613665.jpg)
The "function" knob has a black plastic cover. The other knobs do not. From an eBay advert of a similar system, I've learned that all knobs should have a little cover. I used a bit of moldable plastic that I painted black to make some new ones.
The BNC connectors have turned black. I cleaned them in my little ultrasonic cleaner. Then it dawned on me they were silver! But they cleaned up nicely.
![](https://cdn.hackaday.io/images/8087711691336723376.jpg)
The end result is already a lot better.
![](https://cdn.hackaday.io/images/8392511691336851559.jpg)
