Warning!
Long term durability of this type of board is unclear. After standing on a shelf for a few months many keys stopped working. Not sure if it was oxidation or did some of the traces break. If it was oxidation it might still be fine for use as nonkeyboard PCB as such use cases wouldn't be affected by surface oxidation.
Project goals:
* make a keyboard which is sufficiently thin to fit inside steamdeck official case
* experiment  with making flex PCBs using copper tape and a vinyl cutter (both as cheap flex PCBs and rapid PCB prototyping in general)
Keyboard stackup:
* OHP transparency film (layer 1 backing)
* copper tape
* OHP transparency film (middle layer with holes for making switch connections)
*  copper tape
* OHP transparency film (layer 2 backing)
* vinyl stickers/labels
Usefulness as a  PCB prototyping/ cheap DIY flex PCB creation method.
While the cutting process was relatively quick, weeding process (removal of unwanted parts) was quite slow (~20min for each layer).   Copper tape held better than expected. Not sure what plastic the transparency film is made of, but it started melting at ~240 oC. With soldering iron at 220-225 melting it isn't too much of a problem. But the glue holding copper tape will loosen at that temperature, so you have to be very careful to avoid lifting or sliding the traces around.  Not sure how easy it would be with lead free solder, since with it temperature window between melting solder and the plastic  would be very narrow.  This would be less of an issue with proper materials like kapton.
In theory the glue of copper tape was supposed to be somewhat conductive. With bigger overlapping patches it somewhat worked, but with thinner traces it was somewhat unreliable.  Had to add small dots of soldering to connect the strips of copper tape together more reliably. Uses as wide copper tape as you can get to reduce amount of joints required. 50mm tape is most commonly available, 100mm is somewhat less common. It is also possible to find 20x30cm sheets of copper tape sold for shielding electric guitars, that would probably avoid the issue of having a joint across the middle of PCB, although I am not sure how easy it is to smoothly apply foil that is so wide.
Switch geometry:
One of the initial iterations used ~5mm diameter holes in the middle layer. Those almost didn't work. After making a test with different hole sizes it turned out that ~9-10mm works best. Smaller holes require a lot of force to push, bigger holes have a risk of unintentional connection.
Cutting process
There are two approaches for cutting the tape.
a)
1) apply copper tape with backing paper on the sticky cutting mat
2) cut out with vinyl cutter
3) perform weeding
4) transfer to final backing material  using transfer tape
b)
1) apply the copper tape to backing material
2) cut out using vinyl cutter (use of cutting mat optional)
3) perform weeding
The weeding process is much faster and easier using approach a) while the copper tape is still on the slippery backing paper. Downside is that it only worked for very large shapes. Trying to cut smaller details was nearly impossible, copper tape would lift off, or slide bunch up and tear. When attached to the OHP film the copper tape held in place much better. Using approach b) I was able to cut 0.5mm traces and pads for 0805 smd components, although for reliability I would recommend at least 1mm trace/0.5mm spaces.  For the cutting settings instead of trying to adjust proper blade depth, I just set the minimal cutting pressure to minimum while cutting copper tape and maximum for overall outline.   That way everything can be done in one go without having to remove the blade and attempt to align the offset in multiple operations.
Exporting PCB to SVG for cutting
In kicad export as SVG. Use the options "Current page size" and "Print one page per layer".  Unfortunately when exporting as single SVG the resulting file is quite messy and it's difficult to separate things into the layers. In inkscape import all the svg as pages using Import/select svg file/"Add svg as new page in current file". Once each layer is processed stack up everything back together, it's much easier to do if you used "current page size" as that way you can just shift the objects by page width+spacing instead of manually trying to align the layers.  Kicad will export paths as very thick lines. To prepare them for cutting it's necesarry to: ungroup everything, "Path stroke to path", ungroup again, apply union to everything.
Other attempted and considered things:
Instead of OHP transparency film I also tried lamination film. It has the benefit being able to glue final stackup together by passing everything through lamination machine (before soldering components).  I only had 75  micron (150 for both layers) lamination film which was thinner than OHP film i had. Making it more difficult to cut only copper tape without also cutting the lamination film.  Thicker lamination film is available but not in any of local stores near me.
Software involved
* Keyboard is using QMK firmware.
* PCB Layout was created in Kicad. Warning! Due to copper being partially on the inside the top and bottom layers are somewhat backwards. Be careful not to mixup things with  mirroring.  This project showed a potential room for improvements how kicad exports svg.
* Keyboard definition files and mapping between key positions, scanning matrix, mapping where created with the help of my own tool https://github.com/karliss/kb-editor .  Since the keyboard doesn't have per key diodes, to better deal with multiple keys pressed at the same time the key matrix is a bit more complicated than typical handwired DIY keyboards. Not exactly as complicated as  commercial rubber dome keyboards, but complicated enough where I wouldn't want to manually prepare configuration files for QMK, and update them as I make adjustments for PCB routing reasons.
Final results and conclusions
More warnings
During the process I accidentally routed one of the columns to the RPi pico ground  pin.  It has a ground pin between every 4 IO pins.  Was able to fix it by cutting one of traces with a knife and adding a bodge wire. Attached Kicad project should have the fixed version, but the SVG and QMK config is for the bodged version. If you want to do anything with the attached project files you might want to reexport the SVGs and double check the pins in QMK config.
