Chip package type is WLCSP with diagonal pin pitch 0.4mm. Luckily boards don't appear to have more than 2 layers, and size of vias suggests that all pins are fanned out to the sides.
After careful examination under microscope I've identified following pinout of ribbon cable:
- GND
- "Hidden" button
- SCK
- SDO
- CSB
- SDI
- VDD_IO 2V - voltage is dropped to 1.6V for VDD with local regulator
There are no points on the little pcb available where wires could be soldered without removing connector. Luckily all connector pins have a test points on the next board that ribbon cable connects to.
To confirm pin assignment I tested them with oscilloscope. SCK and CSB pins checked out, but there is no activity on SDI, and SDO.
c00
