This is a project aimed at making a inductance dependent Fan switch with Arduino for removing solder fumes
Project code v1.2.inoSource code of the project simple and cleanino - 1.79 kB - 10/09/2023 at 10:26 |
updated the code to be more efficient and removed the mathematical calculations that were slowing down the arduino.
Added new functionality that allows the coil to be connected to an external driving transistor instead of the Arduino GPIO pin, and the transistor type can be selected in the code.
The inductor is the part that is responsible of detecting the presence of the soldering Iron or any king of ferrous metal that enters its field. The inductor is built around a 12Cm x 17Cm path. The inductor coil is held in place by four Crackers as shows in the images above.
Using four screws tight down the two fans to the side of the wood board
The control board is based on the Arduino Nano. This board contains all the necessary hardware for power regulation and Fan switching. Please see the circuit above to get in touch with all the connections. The board is little junky because it was built the hold an Esp32-can to run a ML code to recognize the soldering iron using a camera “I accidentally burned it”
