Each panels that covers the frame of the SnowByte is made from polycarbonate. Using a 2'x3' panel of polycarbonate I made the following cuts:
![](https://cdn.hackaday.io/images/666611691855194454.jpg)
After cutting the panels, there was still material left for other future projects that could use it.
A project log for SNOWBYTE
Open-Source RC Snowplow that can remove snow from your driveway or sidewalks and can be customized for other tasks around your home.
