SnowByte Test Run
A project log for SNOWBYTE
Open-Source RC Snowplow that can remove snow from your driveway or sidewalks and can be customized for other tasks around your home.
cele9999cele9999 • 08/21/2023 at 22:20•0 Comments
This was after putting everything together and attaching the linear actuator. The speed was also adjusted in the code, it automatically increases the speed as it moves forward. It was done for the purpose of increasing the power to push snow. This can always be adjusted in the code if necessary. By changing the speed variable in the "var setup" section of the code.
