One step closer
A project log for HaLiTerm Prototyping Addon
A breakout-protoboard combo with status LEDs for the handheld Linux terminal.
balazsBalazs 08/16/2023 at 17:470 Comments
The PCBs have finally arrived today, so I was excited to start soldering. Fitting to the epic series of unlucky events I am experiencing recently, I have received 6.2k Ohm resistors instead of 390 Ohm ones. Patience is a virtue...
Update - I soldered together what I could and I am very happy that it works. The LEDs powered by 5mA are a little too bright. I need to start tweaking the resistor values.
