So on to the steering column and its linkage.
This is a small brace, I show it here because I was quite happy with how this turned out. The hole is a bit larger than 5/8", so I had to use a die grinder a bit.
Here is the side view of the steering column
And here is the view from the front. I'm not too happy with how clunky it looks though.
