Given some personal history with the movie, my goal here is to make a tasteful pendant of Eve (from the movie Wall-E) for my wife so she can wear it when we visit Disney theme parks.
Talking to her, I have figured out some criteria:
- She has to want to wear it.
- It has to evoke Eve's appearance for her. My prior design was too flat for this.
- It has to be no larger (width, height, depth) than her compact astrolabe pendant.
- The core effect is Eve's face, an OLED screen (to match the movie effect) that periodically plays an animation.
- My original plan was to use a fast vibration sensor to randomly wake up and play an animation based on the wearer's movement.
- The green leaf circle at some level of detail would be amazing.
- Arms that can pop out would significantly offset other aesthetic shortcomings, like thickness or surface finish.
- A smooth, glossy surface finish would be ideal.
- At my current skill level, this will spend a lot of time on a shelf, so a storage-friendly battery solution is preferred.
- I originally planned on a USB-rechargeable battery for ease of use during travel.
- While I'd love to finally use the parts I have, to actually meet the size requirements and this will probably require new parts.
- I don't yet know if moving the compute module to the back of the neck is feasible.
