This log is a month late... pardon me as I was too busy working my ass off at my internship.
I tried to obtain the dimensions for the hinges from the seller's listing… nope. And the manual never had anything... So, I snapped the highest res photo my phone was capable of along with a 1cm diameter magnet for scaling. Getting rid of the parallax took quite some tries tho (Thus the odd angle and height).
![](https://cdn.hackaday.io/images/9081491691746283200.jpg)
Finally modeled the monitor and some hinges as shown in the next image (There's also a lapse). Some, because I, being a noob at carpentry, ordered a round 7Nm pivot hinge. It was stiff enough to resist the highest torque my hand could generate with my janky leverage made of pliers and m3 bolts. Too much torque. I just donated it to the engineering lab. I also bought a ginormous 3310-sized steel damper hinge for doors that couldn't hold up a bottle of gum let alone the monitor. Too weak... Guess bigger does not equal stronger. Donated that as well. After lurking on the hinges channel of cyberdeck cafe's server, I finally bought a 2.3Nm Hinge that I have yet to unfold and another 0.7Nm damper pivot hinge that was stiff enough for me to work with.
![](https://cdn.hackaday.io/images/3693891691746168452.png)
