Power Management Layout (Sponsored by PCBWay)
A project log for FLOSS Book Serving System
An open-source ereader that can display books from an open, self-hosted server
guyrandy-jean-gillesGuyrandy Jean-Gilles 09/26/2023 at 15:470 Comments
Paying Bills
PCBWay graciously offered to sponsor this revision of the board. With them I've had the flexibility to source parts from multiple trusted sources. They are also quite thorough with their file approval process to avoid any surprises once boards ship. Thanks PCBWay!
Update
I've avoided adding a battery solution since I wanted to focus on prototyping the e-reader features. The previous version of hardware and software had the minimal feature set an e-reader requires, so I finally bit the bullet and implemented portable power. I decided not to implement power on the HAT version of the hardware as that's uncommon for that form factor. I consider that version of the hardware done with buttons as inputs. Once I have touchscreens, I'll do a revision of the HAT.
With respect to portable power, my goal was to keep the device as thin as possible which effectively required a lithium polymer battery. Sparkfun sells a 1250 mAh lipo battery that perfectly fits the carrier board.
I also lifted the design of Sparkfun's battery babysitter and their buck-boost converter to create the charging circuit, 5V regulation, and battery status monitoring. TI's BQ24075 charges the battery and has built in protection circuitry. TI's BQ27441-G1 monitors the battery's charging status, amount other things, and communicates via I2C. Finally, I'm using TI's TPS63701 as a fixed 5V voltage boost converter.
I've configured the ICs to only draw 500 mA from a USB micro connector. I could've pulled as much as 1.5 A from a USB C connector but 1) The tolerances needed to route the connectors I had access to would increase the price and eliminate cheap PCB houses as manufacturers since I want data and power coming from one USB connector. 2) This is a low power e-reading device, so fast charging is not necessary. 3) Limiting current from USB to 500 mA makes the design a little less layout sensitive. Given the physical layout of the Compute Module 4 form factor, if one connector supplies power and USB data, I can either make the 5V power trace short OR make the USB data traces short. I can't do both so I decided to keep the USB data traces short.
If I was pulling the max 1.5 A out of a USB C connector I might've gone with a 4 layer design or at least 2 oz copper, but I'll stick with 2 layers and 1 oz copper because I think I can get away with it. Below is the updated layout followed by the previous version's layout.
Notice that the newest version has only one USB connector. Also notice that the SD card connector flipped 180 degrees because I routed it incorrectly last version. Remember, I don't have any CM4 Lite modules to test the SD card circuitry so I don't have a way to validate that part of the hardware.
We'll see if there are any hardware bugs when I get the boards from PCBWay. For more details on the design and most up-to-date status, check the project's Gitlab repository.
Rich text editor
