Drilled at home, by me. Almost took a finger off.Used the the enclosure DXF to generate a drill guide that I could printEarly enclosure test from AmplifyFUN. Text on the left has gloss cover, text on left does not. I ended up doing a mix of gloss/un-gloss on the "final" version.Really, really happy with how these came out with the black PETG. Printed on Bambu X1C.I think the white board was V2? Had not yet added the EEPROM.
