Connectome editor. Visual programming by neurons.
An artificial nervous system web editor that allows you to program robots.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
A web editor for the artificial nervous system, tentatively titled cogFlux.
https://belkinandrey.github.io/
Open source.
At this stage, there is a virtual hexapod model that can be controlled using the network.
https://youtu.be/IMAXqsx2xAA
So far, it is only possible to create unconditioned reflexes (without training), programming only due to the architecture of the network.
Further plans are to add a scene with a nematode (ringed worm) and possibly a swimming tadpole. Then learning according to Hebb. The mechanism for creating large populations of neurons according to a given pattern. Then there are endless creative possibilities.
I would like to see the management of hard, but I myself am not friends with hard. The source contains examples of interaction between browser tabs via Local Storage.
Rich text editor
