The impedance measurement function is implemented. This can be used as a standalone measurement, but it is also a requirement for the charge and discharge functions. It's basically a verbatim copy of the C++ code. It runs, but I don't have the hardware yet to test it with.
Next will probably be the discharge function, then charge, then autocycle.
