Learning from the previous design, I have made some changes to the layout while keeping the schematic the same. Here are some main changes:
- Highlight 0-ohm jumper resistor: To use the USB 2.0 header, remove these 2 jumpers.
- Highlight GND ports on the top layer
- Thermal relief for the USB header: Easier to solder and desolder
The next October 25th,2023 batch will be V1.1. You can make your own using the provided Gerber, else you can support me through Tindie PicoPD.
