In order to talk to the blue robotics sensors, i needed to connect to them via I2C. The connectors use JST-GH connnectors but I wanted to connect it to the QWIIC port on my microcontroller so I made a little interface board to connect the two.
A project log for Acoustic Monitoring Buoy
Underwater acoustic monitoring using a 4 element array and a surface buoy. Tether enabled by Sparkfun Single Pair Ethernet breakout
