Hi all,
Just a quick update since I was able to gather some initial data.
I made the mistake of grounding the hydrophone ground to frame ground (and effectively seawater). This caused some low frequency stability issues in the pre-amp since it was not expecting the input to be grounded and ended up saturating the ADC (at least this is my working theory).
I am planning on deploying again soon but in the mean time here is some data!
![](https://cdn.hackaday.io/images/9693981700951106485.png)
The vertical stripes in the spectrogram are spots where the waveform clipped which is easier to see / understand in the waveform view.
![](https://cdn.hackaday.io/images/6277211700951125337.png)
If you are wondering what the concave up curve is in the spectrogram, it is the doppler shift of a boat passing the recorder!
