Troubleshooting with 3 key tester
A project log for Wooden Keyboard
A keyboard in a wooden box with a continuous-grain keycap set
kelvin-chowKelvin Chow • 11/13/2023 at 03:19•0 Comments
Making a small scale test for feasibility.  Ignore the defect on the left key, I was using scrap wood.
Before jumping straight into a full-scale keyboard, I made a small scale version of the parts that required some troubleshooting.  This smaller test had 3 sets of key switches/keycaps and a set of keyboard stabilizers for the wide key.
Exploded view of 3-key tester. 3 key switches and 1 set of stabilizers snap into keyplate tray.
For creating the custom parts, my design process was:
Because of this process, the DXF files and STEP files in the project files won't match. The differences are either due to laser cutter kerf adjustments or purposely made bigger so there is material to finish with hand tools.
 A zip file is added in the project logs that contains a STEP file of the entire assembly and individual DXF files for 3 of the parts that were laser cut.  The following few logs will detail the making of this 3 key tester.
