Arm Day
"parle à ma main"-v2
Public Chat
This incredible project is our most ambitious yet. Our goal is to reproduce a human scale arm, and making it interactive trough means we have not chosen for now. We are aiming to reproduce the movement of the user's arm on our artificial one. We wish to educate ourselves on the anatomy of the arm as much as we can and try our best to recreate it correctly, including bones, muscles and maybe even tendons. We'll put our sweat and tears into this project, and hopefully not our blood :)
All the attempt to make the code is on our github. Here is the link for the code:
https://github.com/Eratosteme/ArmCode
input_bien.ino
ino - 7.87 kB - 01/12/2024 at 15:23
Download
Tragic death of bicep n°2.mp4
MPEG-4 Video - 478.74 kB - 01/12/2024 at 10:45
Download
20231201_161158.mp4
Forearm idea
MPEG-4 Video - 18.38 MB - 12/01/2023 at 15:18
Download
bobobo.stl
The second prototype of the humerus (we can put the biceps and tryceps)
Standard Tesselated Geometry - 680.75 kB - 12/01/2023 at 09:01
Download
assembly v20.stl
The look of all the syringe driver
Standard Tesselated Geometry - 6.47 MB - 12/01/2023 at 09:00
Download
View all 21 files
  • 1 × 16cm threaded rod M4
  • 1 × M4x20 screw
  • 1 × M4 nut
  • 1 × M4 washer
  • 1 × 624ZZ bearing
View all 18 components
  • Death of Bicep n°2 on 12/01/2024
    Charmille Delattre01/12/2024 at 10:56 0 comments
    It is with deep sadness and a heavy heart that we announce the tragic passing of Bicep Number 2. At 11:27 AM today, we lost a cherished and irreplaceable member of our community. Bicep Number 2 brought strength, support, and resilience to those who relied on its unwavering presence.
    As we grapple with the profound grief of this unexpected loss, we reflect on the countless moments where Bicep Number 2 provided strength and stability. Its absence leaves a void that cannot be filled, and the weight of this sorrow is felt by all who knew and relied on it.
    During this difficult time, we extend our deepest sympathies to those directly affected by the departure of Bicep Number 2. May you find solace in the memories of the strength it once provided and the impact it had on our lives.
    In memory of Bicep Number 2, we invite you to join us in a moment of reflection and remembrance. Let us honor its legacy by cherishing the strength it symbolized and the support it offered to us all.
    Rest in peace, Bicep Number 2. Your presence will be profoundly missed, and your memory will forever live on in our hearts
  • Forearm idea
    Zurzolo enzo12/01/2023 at 15:24 0 comments
    We just had today the idea of how we will make the forearm moves basically it is just for now the idea but he have put the video of how
  • Update 11/30/2023 Elbow
    Charmille Delattre11/30/2023 at 09:48 0 comments
    Here you can see our lastest version of the elbow :
    (no fingers were burnt in the making of this piece) (some plastic inhalation did happen) (the engineer we used had a sore throat)
  • Update 11/30/2023 syringe driver
    Charmille Delattre11/30/2023 at 09:35 0 comments
    The syringe driver has gone through multiple iterations, going from hand use, to a failed attempt using online 3D models :
    , to finally our lastest and best iteration yet :
  • First arm prototype (without motor)
    Zurzolo enzo10/31/2023 at 15:50 0 comments
    Today was a big day for us. we've made the first arm elbow or something like that prototype. It is a one degree freedom lever. With my strengh we've made the arm lift a 2.5 Kg weight. It may take more but we need to check with the motor how much it can lift. The syringe driver will soon be ready so we hope everything will come to place.
  • 10/25/2023
    Nicolas Marti10/26/2023 at 10:24 0 comments
    The the code 1.3 was finished today.
    https://github.com/Eratosteme/ArmCode/tree/main/Projects/ArmCode_1.3
    -this code enable the use of the syringe driver
          * get user input from the buttons
          * graphical interface with the screen
          * control the motor
    Fixed the issues that plagued the power supply of the motor
            * we made our own USB to Jumper wire adapter
            * connected the ground of the esp32 and motor so that they communicate well despite having different power supply
  • 10/19/2023
    Nicolas Marti10/19/2023 at 17:55 0 comments
    today we did a lot ;)
    - tested several programs and telecommunication library for their compatibility with our esp32 t-display
    - tested the upper limit of the resistance of our system from water pressure
  • First muscle with fiber prototype
    Zurzolo enzo10/19/2023 at 09:00 0 comments
    Last tuesday we have made a connection between 4 muscle prototype. Now on this probably be consider as fiber muscle. The video of it can be seen in the files.
  • Fifth muscle prototype
    Zurzolo enzo10/12/2023 at 12:32 0 comments
    Today we did the fifth muscle prototype. It is basically the same as the fourth one exept that the net used is bigger than the previous one. It will allow the ballon to inflate more and by that to retract more.
  • Fourth muscle prototype
    Zurzolo enzo10/12/2023 at 12:31 0 comments
    We've made the fourth muscle prototype which now contain a way to fix the end of the muscle. It works like the last with water.
View all 19 project logs
