So I broke the Raspberry Pi camera connector. I had already replaced it once and now some of the traces have been ripped. I will buy a new Raspberry Pi zero, connect the camera cable and encase the connector in epoxy. I will also enclose the Raspberry Pi in an ABS enclosure to protect the circuit.
In other fronts, I have fixed the water rocket launcher so that I can adjust the separation between the launch rods. Hopefully I will have the opportunity to test it on Friday and upload a short YouTube video.
Daniel
