After the many failures trying to build a large pressure chamber I have decided to use a single 1-L bottle and build a small rocket instead. This bottle has thick walls and I expect that it can withstand high pressure.
Other than that, I have been making the fins for the rocket, a coupler to connect the pressure chamber to the payload bay, and a nosecone tip.
Daniel
