Programmable power supply for external/target devices
The PiEBridge has a built-in programmable power supply for external/target devices. The user can set the voltage of 2.5-5V (accuracy not less than 2%) with a current not more than 300mA by command from SBCs (e.g., Raspberry Pi).
Users can set this programmed voltage or "ground" to any pin of the output connectors using the built-in 3*10 pin matrix and jumpers.
![](https://cdn.hackaday.io/images/8422771703777870308.jpg)
Connectors
The PiEBridge extension board has built-in 6-pin IDC (2x3 0.1") and 10-pin IDC (2x5 0.1") output connectors.
We recommend using four basic adapters to connect to target systems (e.g., for flashing) via these connectors:
IDC6-IDC6
![](https://assets-global.website-files.com/6438c93ff266bb99a3cab3a6/6565decf02b773cabf302e2c_IDC6_1_43_600-p-500.jpg)
![](https://assets-global.website-files.com/6438c93ff266bb99a3cab3a6/6565decf9be9d97facd9e87f_RPi-PiEBridge-IDC6_1_43_600-p-500.jpg)
IDC6-TC2030
(Tag Connect 6 pins)
![](https://assets-global.website-files.com/6438c93ff266bb99a3cab3a6/6565decfd972e9657cc6aefd_tc2030-idc_43_600-p-500.jpg)
IDC10-IDC10
![](https://assets-global.website-files.com/6438c93ff266bb99a3cab3a6/6565decf9e4e06d5343c6960_IDC10_1_43_600-p-500.jpg)
![](https://assets-global.website-files.com/6438c93ff266bb99a3cab3a6/6565decf5c8f9f39cb693237_RPi-PiEBridge-IDC10_2_43_600-p-500.jpg)
IDC10-TC2050
(Tag Connect 10 pins)
![](https://assets-global.website-files.com/6438c93ff266bb99a3cab3a6/6565decfb64b81c4d36bedbf_tc2050-idc_43_600-p-500.jpg)
Analogs in Segger adapters
PiEBridge adapter | Connects to: | Segger adapter |
IDC6-TC2030 | PCB pads, no mating connector required on PCB Users who do not use any standard for connector pinout can program all chips with compact programming interfaces having 6 or fewer circuits - SWD, SWIM, SPI, etc. | 6-Pin Needle Adapter |
IDC10-IDC10 | the 10-pin 100-mil Intel FPGA JTAG connector | Intel FPGA Adapter
(formerly J-Link Altera Adapter) |
--- | Silicon Labs evaluation boards | SiLabs C2 Adapter |
--- | the SWIM connector and a standard 10-pin connector (STM8) | STM8 Adapter (IDC10) |
IDC10-TC2050 | PCB pads, no mating connector required on PCB | 10-Pin Needle Adapter |
