No code or compile necessary
A project log for Touch Deck (as many menus as you need)
The project uses the Makerfabs-ESP32-S3-SPI-TFT-with-Touch board to produce a Touch-Deck
michael-otooleMichael O'Toole 01/10/2025 at 21:450 Comments
When complete, I will make the binary file available, that way you have a macro keyboard / deck without having to write or compile any code. You still need to write the macros text files and furnish the button icons...
  1. Purchase the LCD...
  2. Make or print a case ..
  3. Write a few macros...
  4. Add icons (images for the buttons)...
  5. Write files to SD card and insert into LCD module...
