With this post, I start my new robotic project. This project will have several important features:
- Architecture-oriented
- Develop the right architecture using architectural best practices
- Result-oriented and minimalistic
- Progress over perfection
- Integration-oriented.
- Reusing existing libraries, projects, etc. Minimum development of individual pieces
- Reusable in my other projects
- It should be done automatically with a good architecture. But I want to make several special decisions to make the project easy to transfer to my another robotic project
What is the project about?
It is a cat companion. A simple robot that can move around, avoid big obstacles and move a stick for playing with a cat.
What is the first step?
I’m starting with the architecture development. I will try to make the most abstract decisions first, leaving the implementation details to the very end.
The first step is development of the use cases. Basically, there are 3 actors for this robot - a cat, a cat owner, and me, a robotic developer. As a developer, It is important for me to have a moving platform (legs, wheels, etc.) reusable by other projects, so it is also reflected in my use case diagram:
![](https://cdn.hackaday.io/images/338611694375777573.jpg)
That is it for now. Next time we will probably define the system requirements based on each use case.
