Testing the electronics and custom mechanisms of the two Degrees of Freedom Rotating and Tilt actuator, operated using Wifi. The module is used for mounting implements in the Agrofelis Robot.
Check it out !A project log for Agrofelis Robot
The Agrofelis Robot is a multipurpose agricultural robot which is energy dense programmable AI-Ready and precision agriculture capable.
Check it out !
