Cloud Self-Hosting guide available
A project log for FindMyCat - The Open Source Pet Tracker
The only pet tracker you will ever need. Months long battery life, works outdoors and indoors. It’s Purr-fectly Empowered.
sahas-chitlangeSahas Chitlange • 10/06/2023 at 03:36•0 Comments
Self hosting instructions are also now available here: https://www.findmycat.io/docs/Hosting
This gives you the ability to host the cloud software on a small computer like Raspberry Pi so you can avoid cloud compute costs that occur if you choose AWS/Azure.
Note that you will need some familiarity dealing with the Router GUI interface (it's pretty easy) to setup port forwarding. The instructions are device specific so please look up your model's instructions.
