[16 Sep]
I was thinking that I was going to set this up and then make a log about it, but it's taking a bit of time so I thought a live-running log format would be better.
So far, I've tried to implement Taipo.c from a QMK source instead of a QMK->Vial fork and made everything barebones and turn things on, one step at a time.
It seems that Taipo and my keyboard works when RGBLIGHT_ENABLE = no in my rules.mk, and fails when set to yes, even without anything RGB related in the keymap.c. Unfortunately, turning rgblight off in my vial config doesn't fix the unresponsiveness issue.
kelvinA
