BB-75 Blasting Machine
- 320V @ 10Joule (75EBCs)
- test circuit 800µA; tactile and optical feedback when continuity
- supply is a 9V battery
- 89m x 165mm x 30mm; 326g
- fuse protected test circuit
- shunted output for EMI protection
- ABS case with rubber boot
- shock and weather resistant
- MSHA conform
DG2plus Ohmmeter
- Autoranging (10Ω, 100kΩ, 10kΩ)
- activated with test button, power-off 15s after load removed
- testing current 1mA
- non sparking brass contact
- supply is a CR2477 battery
- 48mm x 89mm x 30mm; 74g
- completely sealed (IP65)
- low battery indicator
Euroblast X1
- 175mm x 85mm x 43mm; 500g
- 7.4V lithium ion battery; 2200mAh
- 640V / 46Ws / 220µF
- charge time 50 to 70 seconds
- ignition delay 160ms
- type A: 4mJ/Ω; total impedance 580Ω; 3m Cu 230 pieces
- type U: 20mJ/Ω; total impedance 270Ω; 3m Cu 149 pieces
- type HU: 3.3J/Ω; total impedance 12Ω; 3m Cu 4 pieces
- BAM?
RhinoFire Stepper
- supply 9V battery
- test current 15mA
- ignition current 3-6A depending on battery voltage
- 69mm x 147mm x 25mm
Pocket Blaster
- 250V / 2x 220µF / 13.75J
- charging time 18s (new battery)
- 9V battery
- 82mm x 160mm x 42mm; 350g
- BAM-ZM-456
- type U: 20 pieces; 90Ω
- type HU: 3 pieces; 3Ω
- -15°C → +50°C
MICKO 1 dual
- 450V / 40J (Ws)
- 100mm x 175mm x 50mm; 850g
- 4x AA battery
- inner protection resistance 1Ω
- -10°C → +55°C
- type A: type U: type VA: type HU:
DEX C2-55
- 58mm x 155mm x 52mm; 595g
- aluminium housing
- -33°C → 66°C
- 180V / 660µF / 8.58J / charging time 15s
- measurement resolution 1Ω
- ranges 10Ω / 300Ω
- accuracy 10% / 1%
- 4x CR123A battery
- ignition delay ~250ms
HZG hybrid 17J
- 380V / 17J
- -33°C → 63°C
- aluminium housing
- waterproof 7meter / 1h
- battery CR123A
- military approved
HUMMIG Pocket Ignitor
- 6V / 6A
- 4x A/U parallel
- 3x A/U series
- 10 years battery life (Lithium)
Tom
