Mass Production
A project log for LANA TNY
a QT Py / XIAO Compatible board based around the WCH CH23V203
wim-van-goolWim Van Gool 06/20/2024 at 06:180 Comments
Mass production
We've finally pulled the trigger and placed the order for mass production! The boards have arrived and are available in our Lectronz store.
More information regarding which IDE you can use or all the technical documents can be found on our website.
Testing
All boards have been tested and programmed at the end of the assembly line by our own small programmer with pogo-pins. The test firmware can be found on the GitHub repository.
OSHW
We've also received the OSHW certificate thereby making it an official open source hardware design!
