Measuring Displacement using accelerometer and barometer
A project log for Man Hole Alert
A Safety alert system for motorists and pedestrians when drainage covers lift up during floods
josh-joyJosh Joy 09/12/2023 at 11:260 Comments
Measuring altitude by using sensor fusion and considering results from both the Pressure Sensor and Altimeter resulted in accurate measurements only upto a meter. The resolution is far to less to accurately detect a manhole cover rising by a couple of centimeters.
